Help Mobile internet settings
zaacmac
Hey there folks,
Recently purchased the Desire and am happy as larry with the purchase.. one small problem
it would appear it has issues with my networks apn settings..
I'll it admit that I'm a little puzzled after staring at the apn settings for a while and adding the ips etc still not getting any luck.
2degrees (my provider) have attempted ota delivery but no luck.
here are the settings:
WAP Gateway Settings
WAP gateway IP: 118.148.1.118
WAP Gateway Port (WAP2): 8080
WAP Gateway Port (WAP1): 9201
Homepage: 2degrees Mobile Portal
APN: 2degrees
MMS Settings
Homepage: http://mms.2degreesmobile.net.nz:48090
APN: mms
Internet Settings
APN: internet
is some one able to tell me where these go and how to get the phone to recognize them
Thanks in advance!!!!!:)
Hey there folks,
APN: 2degrees
MMS Settings
APN: mms
Internet Settings
APN: internet
When they sent you the settings ota did you switch the phone off & then back on again?
Can't see a way to add them manually at the moment, you could always see if there is an app to enable entering those settings manually.
Hi there,
newly registered so my apologies if I am not following protocol here. I have exactly the same problem as described by the chap earlier in this thread, IE how/where do I access the various phone settings for WAP gateway, Port etc. etc.
I have looked through all the settings on the phone and have been unable to find where any of the more technical stuff is setup. You mentioned you have a fix for this, I would be most appreciative to know what that fix is, thank you.
Hi, it took me a while to figure this out myself, so here it is:
1. Press "menu" button -> followed by settings on the pop-up
2. Press "Wireless & Networks -> Mobile networks (set options for roaming, networks, APNs)
3. Press Access Point Names -> press "menu" button and choose to +New APN
4. Enter all necessary info obtained from your service provider where appropriate
Job done!
Menu > Settings > Wireless and Networks > Mobile Networks > Access Point Names > then Select Operator or create new settings
hi i have a similar problem.have brougt a eclipse dual som 2.2 android phone.
my tesco sim come up as o2.
how do i get round this and get wap and mms working???
