Mobile Network On/Off Widget with Launcher Pro
Anyone know a good one-click widget to switch on/off the mobile network?
Have tried the one from Curvefish but its a shortcut and doesnt bring to the correct page.
Cheers for the suggestions guys am also on Launcher Pro and am missing this stock widget, i also tried the curvefish widget. It worked ok to start with, but then stopped working properly (ie said it was off, when it was actually on and visa versa).
Will try them at lunch time.
Found Widgetsoid2.x the best and really like the customisable options for the look of the widget.
Don't really need the rest of the functions of the app, since i have the MySettings app, but works really well at the moment. Have gone with toggle APN option rather than the rename one, since i think the latter is what curvefish did and that ran into problems.
+1 for Widgetsoid, thanks for the info mate, been looking for a widget that does exactly the same as the sense mobile data widget, and this is it, cheers again.
