As part of my battery saving techniques i often use a widget which turns off the APN. This has direct effect on disabling 3g as it no longer flashes in the task bar, but can someone explain the difference between turning off the APN or turning off the whole 'mobile network' (holding the power button and selecting mobile network off)
Also, do both ways save the same battery?
Thanks..
Thanks..
