Help Mobile Network Problem
Hi all
I have had my sensation since xmas and its been brilliant. Yeesterday though it did something weird. When i tried to connect to internet it just would not connect, i tired for about 30 mins and although the H symbol was on and both arrows were lighting up it just would not connect.
So i pulled the top menu down and turned off the mobile network off and then back on again it suddenly worked, all was sorted and i put it down to a glitch...but then today..
Same thing...it suddenly hung and again i had full network strength, and again the H and up and down arrows were Flashing away but this time i left it for an hour and still no joy, again i turned mobile network settings off and on again and again it burst into life and worked great ever since.
My Wife is on the same network as me and i checked her phone throughout the period mine was down and hers was fine!
Anyone any ideas??
Thanks
Chris
Don't think it's a Sensation thing, I used to get this on my Desire too, although I've only experienced it a couple of times on my Sensation. I think it's a network problem because I've also seen people with iPhones having to go in and disconnect and reconnect their 3G.
Personally I don't think you have a problem it will just happen from time to time, I wouldn't leave it an hour though I'd just disconnect and reconnect, it's normally fine after that.
Although, if it happens a lot then you may have a problem.
Thanks for your reply,
Its not done it since Sunday, but a few times today its hung while on the net, the up arrow was constantly lit and after about a minute both arrows vanished and it said there was no network connection then it re set itself.
its just annoying really
