Mobile Odin problems
Jaay Dogg
Android Expert
Anybody able to get mobile Odin working on our stock rooted ROM FJ12 ? Always says device unsupported ? But most all root guides reference using mobile odin
Change
to.product.model to SPH-D710.
Leave the other entries alone. I can't remember which one since I am at work but it screws up your brightness settings if you change it.
I had the same problem. I believe its where our device I'd is sph-d710vmu.
Thanks B_randon you were right it's just a simple edit of the build prop & reboot. simply erase Where ever you see SPH-D710VMUB or SPH-D710BST just edit the VMUB or BST for boost. Then reboot & odin should be all good.
