Help mobile websites
How do you get the full websites instead of the mobile sites? Standard browser.
In the address bar type about:debug tap go, then go to settings, tap settings, tap debug, tap UAstring and tap desktop. It is only a temporary solution but I think this is the only way to get full websites. I need to do the same thing on my Droid X.
I tried about:debug too, and it doesn't do anything in the XOOM browser.
Worked perfectly, thank you.
Yes you are. So you type the about:debug into the address bar then hit return. Nothing will appear to happen. Then go to the normal settings menu in the top right of the browser. When you go to settings on the left you will now see a new option called debug, go there and the second from the top is ua string touch it and change it to desk top. WA a law you are now surfing normally.
