Help MobiUcare | How to Force Remove ?
Rajiev
Hi,
I've Installed MobiUcare and I think I lost the password :eek:
Phone runs fine but I'm worried if I ever have the need to use this app (my phone lost), it wont work. (plus its PITA when u know that a uncontrollable app is there in your phone)
I think the space in my password is erroneously recognised by my the app when I send a SMS to show the app (yeah, the app is in hidden mode).
1. Anyone have a solution to un-install this app? Will rooting help ?
2. Or anyone know if a space (" ") in the password make this app go crazy?
Have a unrooted SGS 2
Hi,
Using RootExplorer, search for CTP_PREFS.xml. Password should be located after "pref_password">
Plus you could also search for com.mobiucare.client.preferences.xml and change the preference "pref_protect_removal" value="false" /> instead of the value being true. BTW, you will have to go to the actual directory from the search listing to adjust permissions for modification if necessary. I just add User execute and then deselected it after I was finished.
Indagate
Any idea in what folder it might be?
Indagate
