Root Mobsters rom overclocking
Akumin
So I cant find a clear answer I am rooted and running Midnight rom but this ****** EATS my battery! I hear mobsters is more "Fuel Efficient" i guess you can say. Can I use a kernel tuner like anthrax? I just wanna run 1.55 ghz just cause I play GTA 3 and it runs perfect at that setting.
Also mobsters is Android 4.04 unlike Midnight which is 4.03
anyone have a word on this?
Mobster's ROM comes with his power kernel, which cannot be overclocked, but you can still use Mobster's ROM and flash a different kernel (like anthrax or jmz), if you really want to overclock.
I will say that Mobz is right, and the rom is pretty awesome with the kernel it comes with. That being said, I can confirm that you CAN use a kernel tuner with a different kernel (I think with the tuner, you might be able to change the governor of the default kernel, but not the clock speed). Hope this helps.
IMO its not necessary I've never seen a lag on my Rom and trust me i play Graphic intensive games too
whats the clock settings on this rom stock? will it allow me to play GTA 3? Cause I noticed anything under 1.3 ghz it likes to chug on GTA 3 on midnight rom. 1.5 on midnight though the rom is as SMOOTH as butter!
Power Kernel, the kernel that comes with Mobster ROM, runs at stock 1.2GHz. It runs amazingly smooth though, because unlike Anthrax and JMZ's overclock kernel it keeps both cores on all the time instead of letting 1 go to sleep. 1.2GHz true dual core > overclocked single core.
I dont Understand why people always think they need to overclock.
Banished is right
They probably want high benchmarks
Ya. Nothing wrong with overclocking. But it seems like people just want to do it cause it seems cool or something. I run a overclock kernel once in a while.just for a change. It seems like the only thing that is much faster is battery drain..
Hey didn't you say that you ran your phone with the performance governor somewhere around the forums ? lol. But anyway on mobster rom and mobster barebones I can probably run the phone at 600mhz and undervolt pretty low too. :)
I do a lot of times. And still great battery life
