Root [MOD] 10% Battery Increments for ApeX
Brav1111
First of, Awesome work on ApeX Fab!
Second, I just wanted to start a thread and provide you with a couple battery alternatives for ApeX.
The usual warnings:
Flash everything in the thread at your own risk.
Anyone supplying a zip is not responsible for your phone.
Take a backup of your current setup so you have something to go back to if you dislike the changes.
For Apex 2.0 Beta ONLY:
Both include the apeX Boot Animation created by plower.net and also a modified battery xml to get the 10% battery readings.
Green Circle Battery with % (Images created by bhmstuff).
Notification Bar Revert with % (This one also includes some other icons I prefer from Gingerbread - 3G, Phone Signal, Sliders, ...).
I don't recall where I grabbed the battery xml from, but if you just want to keep what you have as a battery and enable the 10% readings see brewcrewwheels post (#60):
http://androidforums.com/droid-x-al...pex-v2-0-0-beta-5-3-2011-a-2.html#post2644956
If you have your own battery mods, go ahead and post them in this thread.
How about adding the no clock mod to this also. Taught I would ask for it since it relates to the notification bar also.
I haven't paid too much attention to that mod, but it should be fairly easy to add, but I won't be able to look at it until tomorrow.
I assume you are wanting it combined with one of the above?
Nope, I already dl this file and installed it. :D But if you get it I will be more then happy to apply it also.
Here is the clock removal in post #47:
http://androidforums.com/droid-x-al...-apex-v2-0-0-beta-5-3-2011-a.html#post2644270
Just a side note, if you apply the "Reverted" zip from above then the clock removal, the 3G, WiFi and maybe some other icons will get changed to the apeX default.
If you apply the Revert after the clock removal, the clock will come back.
If you install the Circle after the clock removal, the clock will come back.
i actually like the stock battery increments fab has introduced in the new apex
but regardless you are doing soon good work, and hope you continue to help out :)
Yeah I haven't quite updated this to RC2 yet, but would if someone asked for it....
I like his new battery as well.
