Root [MOD] CM7 invisible Holo lockring - glow when pressed
thangfish
Android Expert
This is a very simple mod to make your Holo (ICS style) lockring and lock icon invisible. It will "glow" a color when pressed.
I made this for my own use, because I don't like the looks of the lockring on my lockscreen wallpaper.
It's only really practical if you use the "minimalistic" style, with one unlock ring in the center.
I have included a template to help make your own lockscreen wallpaper, with an "element" centered where the lockring would be so you
know where to press.
Requirements:
The Metamorph app from the market to apply the mod.
CM7 v7.2 as I don't believe earlier versions have the ICS style Holo lockrings.
Should work on any device running this version or later.
Use at your own risk, etc...
A word of warning...
This will also affect your call answer screen if you use the Holo rings on it. No big deal really... You still have the red and green phone icons.
It will also reset your homescreen wallpaper back to the default. Just change it back.
That's all the issues I can think of.
I have also included an "undo" morph so you can go back to stock, if you don't like it.
This mod does NOT replace your framework, like some of the others... That's why these use Metamorph instead of just flashing a new framework. (Thanks to Ziggy for advice!) Very small downloads.
Download mod here
(Hit the little icon to the right if you can't see the full file name in my BOX folder)
Files are as follows (color when pressed)
1 white
2 fire (orange inside to yellow edge)
3 glass (translucent "glass" ring)
4 blue
5 yellow
6 orange
7 restore (back to original)
8 purple
9 black template with hole to help you make your wallpaper
To use the template:
Open it in Photoshop.
Open your intended lockscreen wallpaper image.
Copy and paste it to the template.
Bring template layer to the front.
Move your image until the element you want to press shows through the hole.
Trash the template layer.
Save as: a name you like, and pick it for your lockscreen wallpaper.
Lockscreen before mod:
Lockscreen after mod (purple glow)
Purple glow when pressed
When moved
Another example of white glow:
When pressed
