Root [MOD] [CM7] Mobster Tweaks v6
Mobstergunz
Android Expert
Mobster Tweaks v6
by Mobstergunz
Mod Features:
Battery Tweaks
Performance Tweaks
Touchscreen Tweaks
Faster Media Streaming
Faster Data Speeds Tweak
Sony Xloud Engine - separate in Sony Mods
Sony Bravia Engine
HD Youtube
g60 style r0.10 build.prop w/ HTC Incredible 2 mod
Installation Instructions:
Flash in ClockWorkMod Recovery
Downloads:
Sony Engines - Sony Engine Mods (CM7).zip
CM7 based Roms only - Mobster Tweaks v6 (CM7).zip
Bugs:
Sony Mods - The Xloud Engine seems to be giving random bugs one being no speaker phone during calls however these Engines greatly improve Videos, Photos, Audio, Camera / Camcorder, and even raises Volume through Headphones
DISCLAIMER: I AM NOT RESPONSIBLE FOR ANY DAMAGE DONE WHILE USING THIS MOD
im not sure if its just me but touching dsp manager after installing sony literally shuts the device down rebooting it.
That's probably because of the xLoud engine its does cause some bugs even on froyo that's why Mobster Tweaks v6 only includes the Bravia engine
its ok as long as u config dsp manager b4 installing it :) i hear a difference in sound. keep up the great work! u should try porting beats audio. xda forums has it but only one truely works for the triumph :) it sounds amazing wif bravia :D
I dont know if this has been brought up before, prob has, but would this work for MUIU or no
To install this I just flash the mod in recovery? Or do I also have to wipe cache and wipe dalvik cache as well? I am currently running CM7 7.2 rc1 - g60 style r0.10
Another dumb question, LOL ... Do I need to flash both the Sony Engine Mods (CM7) and Mobster Tweaks v6 (CM7) or just the Mobster Tweaks v6 (CM7) will do?
Since installing it, my WiFi is randomly turning itself on. :confused:
I turn it off and check later and it's back on again. Weird.
Don't know if anyone else is experiencing this but my wifi connects but doesn't load any webpages or YouTube videos.. =(
Anyone else tried the camera after installing? I'm getting a weird glitch where the preview is cut in half >_<
Just make a backup before you flash. If anything goes wrong restore your backup. Im on CM7g60 r0.11 with bkernel on top and everything works fine so far. I installed both.
I had the same problem today with wifi that someone earlier said, it kept turning itself back on, seconds after i switched it off, had to run my restore back to regular g60 11
As an experiment I restored a clean g60 v.11 and then just installed the modified Tweaks' build.prop by itself. The WiFi started turning itself on again, so it has to be caused by something in the build.prop alone. I did notice that so far a reboot has made the WiFi problem stop.
So I don't get it. After flashing these is there something else you have to do? I don't see or hear any difference at all. I thought itmight fix the volume thing. I mean the volume is plenty loud but if you press volume down like twice you can't hear it. So its kinda like its super super loud or you can't hear it. No in between....anyways how do you use these tweaks? Do they only work with certain apps or something?
