Root [MOD]CRT Animation[Beats Roms][Updated 4/20]
Man truly thank you for stepping up to the plate on this phone. You have done a damn fine job. With you and Blood working on the Boost versions I think this is going to really expedite the awesomeness of this phone
Wow, I agree!! |Monster| you never cease to amaze!! Many many thanks!!!!! The CRT Animation is awesome..
I noticed other phones that have the CRT Animation, works both when turning the screen off as well as turning it on. Is there a way to make ours have it when we turn the screen on as well? THANKS Again!!
Does it work with the current beats rom(BOOST ZVC: v.1.2zvc/zv4_21)?
I wouldn't recommend using this at this point not knowing if it affects the ROM. I did notice before it would change the Battery Icon when flashing to it, so I would wait til |Monster| comes back and gives us the go ahead..
updated for MB v2 STOCK ONLY. It will not work with the themes tho. If u want me to add it to your theme send me the framework-res from inside the zip, and ill send it back to you.
I also replaced drivers in this too, so let me know about BT. I dont have wireless headphones to test it with, i also havent checked BT ftp. Let me know once you test this
here is my framwork-res.apk:
http://dl.dropbox.com/u/70114959/framework-res.apk
Will the BT fixes be included in the framwork-res.apk when u send it back to me?
you will have to swap out the files in my crtv2.zip. Ill send u back the framework, then put that and systemUI in the corresponding folders, and done.
give me a minute and u will have this file back
update: just checked BT ftp and it worked to my MBP
ok cool.. going to lunch will check/test after.. thanks man!
Well i haven't flashed this yet.. though check out my speedtest w/o WiFi. I never tested before because I always assumed if I see the 3G symbol it was working.. Another odd thing is seems like my UL is always faster than my DL even with WiFi..
Re flash it? Flash a new prl? Install 3g super charger? Don't blame the rom, take it upon yourself to get the best experience YOU are able
Sent from my LG-LG855 using Tapatalk 2 Beta-5
