b_randon14
Android Expert
What errors are they?
its something like (expected 2 args, got 3) and (expected 3 args, got 4) i am completely clueless when it come to updater-scripts. thats why i use other people's and sometimes get lucky when adding lines to them LOL
oh did you check your pm?
I see. Those errors happen when there's a mismatch between your updater-script arguments and what the updater-binary is expecting.
for example, in some of the updater-scripts, you see this type of code:
mount("ext4", "/dev/block/mmcblk0p7", "/system");
where there's only 3 arguments.
In other scripts, you see this:
mount("ext3", "EMMC", "/dev/block/mmcblk0p7", "/system");
where there's 4 arguments.
I'm pretty sure that this difference is in the updater-binary file. So you just need the correct binary file for the format that you are using (or use the correct format for the binary file that you are using.)
oh well, at least now i know what was going wrong. thanks mantera
The links in the original post do not appear to be functioning. Does anyone have these that they can share? Thanks.
