Root [MOD/GUIDE] How to change your lockscreen background
ShinySide
Extreme Android User
Yea so just like the title says. This is how you make your lockscreen background an image instead of being transparent.
So first a preview:
Lock screen background - YouTube
Now how to do it.
Simple and easy.
1. Decompile the frameworkres.apk
2. Navigate to the res>layout>keyguard_screen_tab_unlock.xml and with notepad++, and find the line:
Code:
<RelativeLayout android:gravity="center_horizontal" android:id="@id/root" android:background="#70000000" android:layout_width="fill_parent" android:layout_height="fill_parent"
and change it to:
Code:
<RelativeLayout android:gravity="center_horizontal" android:id="@id/root" android:background="@drawable/lockscreen_background" android:layout_width="fill_parent" android:layout_height="fill_parent"
3. now add a 480x800 png image to the res>drawable-hpdi folder and name it "lockscreen_background"
4. Recompile and flash/push to phone. (dont forget the META folder after recompile ;) )
5. Enjoy. And youre welcome. ;)
So first a preview:
Now how to do it.
Simple and easy.
Code:
and change it to:
Code:
Nicee One!!!!!!!!11 ;)
Hey Shiny can you help me i cant seem to compile the apk after i edit the xml and add my image. I did everything you said. I edited the xml, replaced the line with the one you provided and inserted a 480x800 png to res>drawable-hpdi and name it lockscreen_background.png and apktool gives me a bunch of error public symbol declared here not defined. I also tried to use apkmultitools and couldn't recompile either. Im using rom Number Two with no themes. But i do use dodol to use a 5 stitch wallpaper don't know if that's creating a problem. Also i used photoshop cs4 to create my background and when im about to save it asks me if i want to interlace the png and i said no. Again dont know if thats the culprit.
You need to swap out the drawable-hdpi folder of your apk with the drawable-hdpi with the one that's is ld-Lg stock mod. Decompile and make your changes and add your image and then recompile. Then once it's recompiled swap back the drawable hdpi folder and add the Meta folder to the new apk. ;)
