Root [Mod] Improve GPS connectivity
phw8558
Android Expert
I take no credit for this, I am just simply posting the solution I found that helped with my poor gps readouts. If your GPS is already fast you probably won't notice much change.
Simply follow this link and follow instructions. http://forum.xda-developers.com/showthread.php?t=1325033. You will find a very informative OP that should answer any questions you have before installation.
*I recommend the version "Google Specific No-SSL v3.1" or " Google Specific v3.1" This took me from a max of 6 fixed satellites (if I was lucky, usually hovered around 3-4) to 11 max satellites (hovers around 9). There are a variety of free apps on Play that will show you how many active satellites you are connecting to. One is "GPS essentials" and another good one is "GPS status and toolbox". Iwill post a screenshot when tapatalk is working.
*PS can just be flashed through recovery.. super easy
*PPS donate to crypted if this works for you!
6 was the most I saw before, although at most times I was lucky to get 4. This screenshot is after the patch
I actually didn't see much improvement with this - connecting to 8 satellites before and after updating the conf file, at about the same speed as well. I'll have to do some testing in another location before I can make any solid conclusions.
Yeah I think I should revise the OP, because if you already have good connectivity you probably won't see to much of an improvement. More for people having problems.
In your case 8 is a pretty solid number.
Someone coming from 4 (which I believe is the minimum needed to fix your location) would benefit alot more
My signal was more stable with the mod (by one satellite) but I was able to connect to one more satellite without the mod.
In the end, it's wash.
Apparently the problem with the GPS dates back to some Sprint 3d users. I guess I was one of the unlucky virgin users to get it. However, this has taken my error (In meters) from 100-200m before the patch to 5-10m. Also my indicator no longer "moves" when I'm not moving.
Was just curious to try, but no change, though mine works good. This phone is nothing like the triumph, couldn't get a gps lock with that phone if you held it ten feet in the air.
Never had the triumph but that's what I've been hearing. My problem on this phone wasn't that it took long to lock in its just that it was highly inaccurate. Locked me in instant, although it was half a mile away.:thumbdown:
What a POS the Triumph was....so glad to be rid of that paperweight.
