Root [MOD] Lidroid Notification Toggles for SuperROM B13 v2
DBlake
This is my second Android mod, this time the toggles from Lidroid for our phones! Yes folks, these are native notification toggles, not the Power Toggles app from the Play Store!
After about 1,000 or so recompiles and hours of "why the **** won't this work?", I finally got it to work! Most toggles are fully functional, although there are some toggles I can't test (data toggle being one of them). This is my first step into Android modding/development.
DOWNLOAD (v1 - Green): Dropbox (direct) | Mediafire
DOWNLOAD (v1 - White): Dropbox (direct) | Mediafire
Released! Though I can't change the topic title... Would a moderator please change the [PREVIEW] to [MOD] in the title?
You can change it. Click the Go Advanced button at the bottom of your post while in edit mode.
Oops, didn't know that. Thanks.
What do you think of this mod?
Looks pretty cool. IMHO, the green would look better in white. Not sure if you know this, but chevanlol360 ported this for the sequent and used it in his rom. I have not tried either of them. Currently running cm11.
looks pretty cool! Let me ask you can these toggles be customized like change color, add and take away toggles, does it slide over, etc or just as it is? thanks for the great work
Colors no, but I did add a new setting in Settings called "Notification toggles" where you can re-order the toggles as well as add and remove them. I forgot to mention that.
I'll make a version with white icons soon. Just wanted to get the mod released before it was delayed further. Release early, release often as they say.
Yeah I will be waiting for the white ones. I use Power Toggles and love the way I configured the white
How's this look to you?
Thanks DBlake. I'm loving it. I'm actually still using power toggles under it but might do away with them soon.
Hey bro so are the toggles working out for you? let me know which one you prefer the lidroid or power toggles cause i'm trying to decide myself, i really like power toggles have had it for a while but these seem pretty cool too by the way how many toggles are there, do they all work and do they slide over? too bad they're not blue that would match my phone, well just wanna know how they compare thanks:)
I am using power toggles because of the second row. Plus I like the customization. I like using lidroid too but I couldn't get the torch to work, which I use a lot.
yeah i was thinking the same thing although this Lidroid toggle is nice still think Power Toggles have some advantages over it like customization is a big thing for me, the second row plus ability to add apps and custom actions, you did mentioned flashlight wouldn't work i believe Chevanlol360 has the same toggles which he ported to his own rom and mentioned flashlight, reboot, usb debug and hotspot toggles don't work nevertheless these guys did a great job but i'm sticking with PT for the time being. So just to let you know i used to use the flashlight toggle but not anymore since Gravity Box has some nice features i have it when long press the homekey the flashlight comes on but that's not all you can do a bunch of things with it. thanks :)
