bump (my last post on here)
Okay, here's what you need to do if Init.d is missing.
1. Go through the steps in the main post, download script manager, install it, give it SU permissions.
2. use root explorer to go into system/etc and CREATE the init.d folder (IMPORTANT) it needs to be in LOWER CASE
3. Browse back to the SD card, and move the two scripts to the folder you just created, then go through the sequential steps in the main post to finish installation.
Remember, even though you'll get the chmod 444 error lock the screen, and it'll work.
Please hit the "thanks" button if I helped.
and yw
