bouchigo
Android Expert
This is for stock GB 4.5.602. I decided to go ahead and do it since people keep wanting to use the old .596 mods on their .602 setup.
I haven't tested these as I am not on .602, so you guys will have to let me know if they work as intended.
Enjoy
If you have bootloop issues use this (I suggest you use this before applying the mods, but it's up to you):
GB_2.3.3_4.5.602_Deodexer.zip
CRT only
http://www.mediafire.com/?ibw4zw19d1lvcrp
Stock Pattern Unlock (no CRT, Rotation, or Battery)
Stock_GB_4.5.602_Remove_SlideLock_PatternUnlock.zip
CRT plus Pattern Unlock
Stock_GB_4.5.602_CRT_PatternUnlock.zip
CRT, Rotation, plus Pattern Unlock
Stock_GB_4.5.602_CRT_Rotation_PatternUnlock.zip
CRT, Blue battery10%, plus Pattern Unlock
Stock_GB_4.5.602_CRT_Blue_Batt_PatternUnlock.zip
CRT, Blue battery 10%, Rotation, plus Pattern Unlock
Stock_GB_4.5.602_CRT_Blue_Batt_PatternUnlock_Rotation.zip
Remove Mods (if you no longer want the mods, use this to remove them):
Remove_Mods_4.5.602.zip
Enjoy
CRT only
