Mods [MOD][XPOSED][4.0+]Android Theme Engine- Theme you Phone with Xposed module [Root only]
Ex-Themer Now Know as Android Theme Engine Update 06/03/15
Important Test Release---- here
Android Theme Engine--- Now one module for all version (ICS,JB & KitKat)
[Using a third party App/Module along with a theme.apk will be a thing of the PAST]
[A Warehouse Of Android Themes]
Download
Version 6.0.3
Version 6.0.2
Version 4.1.2
Version 4.1.3
4.2.0 (LG support added) For installation and not working issue refer post no. 14
Version 4.2.1
Version 5.0 ---- New feature added---- Now theme Alarm, BT, Vibrate, Silent icons also.
Android Theme Engine allows you to theme your Android Device on the go without the need to flash or install any extra file. Most of the Mods and Themes can even be applied without the need to restart the device.
Android Theme Engine is the one stop shopping mall for changing the look of your device. It is a treasure full of themes and other unique options.
It supports all Android Versions From 4.0 and Up (ICS, JB & KitKat). Different Brand specific Roms are also supported.
Features of this Module:
THEMES YOUR ANDROID MOBILE AT THE SYSTEM LEVEL WITH THE HELP OF XPOSED MODULE. NOW NO NEED TO HUNT FOR DIFFERENT THEME APPLICATIONS FOR THEMEING YOUR MOBILE PHONE AS PER YOUR LIKING.
Status Bar Themes :
Choose from different battery icons, signal bars, notifications, quick toggles theme etc. on the go
Framework Tweaks:
Change the look of switch, progress bar, system animations etc.
Independent:
The Module Theme's your mobile itself without the need of any extra third party apps or modules.
Now Theme Your Mobile On The Go without the need to install third party theme apps for different parts of your mobile. This Module is the One Stop Treasure For Theme Lovers.
Download either from the download link provided Above, or from xposed repo download section
New Feature Added for Stock Android Phones----- Toggle Themeing & Lock Rings Style Changer
Version 4.1.2 Changelogs:
Added New Themes : Signal, Wifi, Nav Bars & Switches
Removed Progress bar Color Changer
Added Lock Rings Style Changer
Version 4.1: Added progress/Volume bar Color Changer
Update can be done from Xposed Repo Download section.
Guys Please Note That After Updating To A Newer Version You Need To Restart Your Device Once For The New Mods and Themes To Work.
IF FOR ANY REASON THIS MODULE DOES NOT WORK'S FOR YOU, READ THIS POST : GUIDE
Requirements
Android Theme Engine gets an Update : New features
Change Log: Version 4.1
Added 3 new battery themes
Added progress/Volume bar Color Changer (Stock Android+Samsung TW)
Fixed Two Signal bar themes: Ios7 & TW 4 Style
Update from Xposed Repo
Update Time
Version 4.1.2 Released and available for Download or See Xposed Repo download section
Changelog:
Added New Themes:
Wifi, Signal, Nav Bar & Switch
Added New Feature to change the style of Lock Ring (The new feature is a Pre- Alpha Release as it could not tested due to unavailability of Stock Android Rom phone). Hence, Feature may and may not work for Stock Android Rom users.
P.S - This is only available to users with Stock Android Rom. If all goes well other brand add on will follow.
So, I tried this yesterday and all I got to work was changing the color of the clock. I'm hooked on the ics blue color and that's what I wanted to change everything to. At least make them all blue, clock, battery bar, signal bat, and wifi bar. Well after seeing these a few times and restarting each time after I was only able to get the clock to change. I'm stock rooted, Verizon LG G2. Updated to the newest update available at this time. If there is anything you guys can do that would be awesome. Otherwise, at this time I'm still debating flashing the cloudy G3 rom.
4.2.0 Changelog:
Lg support added
Nav bar themes Now
Signal Bar themes Now
Wifi themes Now
Clock themes
Important things to consider:
Please uninstall the old version completely and do a fresh install of new verion.
For LG users need to select LG rom option as shown in the screenshot and enable desired themes and check boxes.
Provide Super user access and activate and reboot the phone.
If you do not see anything themed then uncheck the lg rom checkbox and do a system ui restart.
once you see wifi icons themed then re check the lg rom check box and do the system ui restart. It should work afterwards.
Please leave your comment if you face any issues we will get you through.
Direct link can be found in few minutes in Opening post.
Also, repo update will be there too.
Preview of Version 4.2.1 upcoming release
What will be New
NAV Bar Themes
Signal Bar Theme
Percentage Battery Theme for ICS/JB Users
The wait for the new version of Android Theme Engine has come to an end.
Version 4.2.1 Released and ready to be downloaded via Xposed Repo download section or Direct download link in Opening Post.
What's New:
Themes.... Themes.... and themes...
New Battery number percentage (5%) added
Siganl Bar Themes
Wifi Themes
Navigation Bar Themes
And Many more not listed.
Minor Bug fixes
It is always wise step to do a fresh install.
We hope you will like the new themes and encourage us by dropping few comments and feedback/advise.
Guys, We are again back with new update and this time we have added new feature to theme Alarm, BT, Ringer mute, Vibrate icons like famous brands HTC, LG. (More will be added during the regular update process). Check the screenshot for one of the new feature icon pack
Also, As usual, update brings new themes for Signal Bar, Navigation Bar.
Some bug fixes.
Correction with version id not showing correct in previous version.
The download can be done by xposed installer download section by refreshing or from the opening post link.
Hope you enjoy the same.
Please feel free to leave comments.
Version 6.0 Pre Release --- Test Version
Change Log: Please Note: Fresh install is need for this test version. So Please restart the phone after uninstall the old version and then fresh install.
Material UI
Tab slide View
Code fix for Icon themeing Samsung Phones
Code fix for LG
Working Navigation bar for lg with same theme in home, drawer and in app view. Please select the following option in order to achieve same navigation theme in all window.
settings>Front touch buttons>colour> Black then xposed module theme of your choice
We are working hard to make this module working for everyone hence we only request you to test it and leave your detailed comments of what you liked and what you would like us to change.
Please leave your phone model and android version details also.
Download Link
Version 6.0.2
Change Log:
ChangeLog:
Corrected Code for Samsung and other brands phones for breaking the moduel when applying status bar icon themes
Corrected more icon pack size
More Stability
P.S- A fresh Install is required to avoid any issues but this module can be installed over the previous version, a reboot is must for module to work.
Version 6.0.3
Changes:
Added New Themes
Code fixes
Might Require a fresh install in few cases.
If it stops working please press Install/update button in xposed installer framerwork and reboot.
