craigcrawford1988
Okay, so people are having so much trouble with the Windows version of R4 I decided to put TinyCoreLinux and the HTC Desire root into an ISO that is ready to burn and use.
- First of all, read the information here and create a goldcard if you are rooting a device that has a ROM by a network operator.
- Once you have read that download TinyCoreLinux 2.11 with HTC Desire root r4.
- Burn the disc (or use UNetbootin to make a USB flash device if you know how to).
- Put the disc (or USB flash device) into the computer you wish to use for updating the HTC Desire and turn the HTC Desire off.
- Goldcard step only: Insert the goldcard into the phone.
- Start the HTC Desire in bootloader by holding back and turning it on by the power button.
- Connect the USB cable to the phone and PC and boot the TinyCoreLinux CD (or USB flash).
- Open a terminal using the 2nd icon at the bottom on TinyCoreLinux and type the following commands:
Code:sudo mkdir /mnt/cdrom sudo mount /dev/cdrom /mnt/cdrom cd /mnt/cdrom/desire - Now type the following and wait until the phone restarts back into the white bootloader screen:
Code:sudo ./step1.sh - Goldcard step only: Turn the phone off via the bootloader menu (or pull the battery and USB cable) and remove the goldcard. Put a non-goldcard SD into the phone or reformat the goldcard and put it into the phone. Put the phone back into bootloader mode (back and power button).
- Select the BOOTLOADER (wait until the blue text HBOOT changes to HBOOT USB PLUG) and then RECOVERY option, wait for the phone to go to a black screen with a phone icon and red exclamation mark.
- In terminal type the following command:
Code:sudo ./step2.sh - Once the phone has finished, you will see a screen with lots of green text. Use the optical tracker to navigate the menu to select Wipe and then press Wipe data/factory reset.
- Once complete you should be back in the main menu. Now select the option to apply an update from a .zip archive. Choose rootedupdate.zip.
- Once completed your phone should be rooted!
Code:
sudo ./recovery-linux.sh
