Root Modified build.prop...
some apps just wont work with certain phones,you cant expect to have ALL the apps in the market work lol.theirs just some that wont work with our device.What apps are you trying to install if i may ask?
Well I fixed my problem. I had changed my LCD density to a lv unknown to the market that why not ONE app would download lolz!! I have my LCD density at 210 I changed it just opening my build.prop in text editor in root explorer. But another user advised me to use LCD density modder with the playestore fix and it works beautiful. I have a modified playstore that thinks my phone is a 240 when in reality I have it set at 210.:) so my problem fixed!
A playstore fix?
You need to install LCD Density Modder to fix playstore compatibility.
LCD Density Modder
Real simple just follow directions in Apk.
Choose density.
Choose density you want play store to think you have.
then install. It should reboot and once rebooted open play store and you should have to re-login.
Then check and see what apk you couldn't download before and see if its available.
