Mods for gco1 stock
Stock GC01 is Odexed. Mods that work for Odexed GB27 (the Sprint labeled version of the Same ROM) you can use.
Every time I download one my phone screws up I went and did the status bar one for od one and when I rebooted I had no status bar at all and had to restore in recovery
which exact file are you trying? Did you calculate the checksum of the file and compare it to make sure you didn't have a bad download?
How do you do that like I tried inverted google now made phone freeze but inverted Facebook and Gmail work fine I downloaded only mods for gb27 and also I had a back up and I tried to use it and it said mismatch sum I could not use it
get yourself es file manager from the play store. When you download the mod to your phone ,look at the properties of the file with es file manager and have it calculate the md5. Then compare it to the md5 shown on the website.
