Root [Mods][JB]Deodexed app & framework|Battery with %|4x5-5x4 Appdrawer|Landscape mode
Hi together. I made some Mods for your JB rom, based on the flashable zip from simonsimons34 (thanks to him).
I deodexed app & framework folder, good base for modding ;)
You can have stock battery with %, appdrawer with 5x4 or 4x5 lines and landscape mode activated in homescreen and appdrawer. All as separate zip files for flashing in recovery. You can choose what you want!
Just head over here for pictures and download. (only for boost user)
Cricket user please follow this link.
Big thanks also goes to wetbiker7 For testing!
Have fun.
ooOooh! Thanks o_splatterhand!!
Edit: With this, do you think I could use UOT kitchen to finally theme the framework file? I tried before, but it didn't work... probably because it was odex or something.
Edit 2: Will this wipe all user data? Or will it only replace a few system files?
It don't touch data partition.
It deletes system/app/ & system/framework/ folders and its flashing exactly the same as deodexed back.
But of course a backup is never wrong, cause always can something go wrong!
And yes UOT works ;)
So stoked for this one! My biggest complaint about sense has always been the lack of landscape mode. I drive a lot with my phone turned sideways in a holder. :-)
Sent from my C525c using Tapatalk 2
All in Sense is already prepared for landscape mode, it needed only to be switched on.
I just meant that it's quite bothersome that sense doesn't have landscape out of the box. I think all phones should come with landscape enabled as an option by default. :-)
hello o_splatterhand, can u please port to the cricket htc one sv (k2plccl)? its running jelly bean 2.04.1050.3 i can supply whatever folders and files u may need and test also. thanks for all the great work u do on the htc one sv.
I did already, lol. But there was a problem (nothing serious), and i had to do it again.
Til now i have no info from my tester, if the second try was more successful.
awesome work. if u need another tester let me know. i like the landscape option. i had it in cm7 on my old, old huawei ascend m860. lol.
Could this mod work without the battery percentage in the middle? Is there anyway to take it out
