Help Moment-Blackjack Battery Interchageability?
BirdieMN
I know I recall reading that someone had successfully used a Blackjack battery in a Moment. My question is, are they the same battery, and if not, will the moment battery fit into and charge in a Blackjack?
I'm thinking about buying a cheap used Blackjack and using it as a charger for a spare battery for my Moment.
in a pinch, i've actually used the samsung instinct battery in my moment. Although it is a smaller batter, and alot less life, it still works. You just need to line up the contacts.
bought a generic blackjack battery off of ebay. While it did work, it never seemed to hold a charge anything close to the Moment's battery.
