After a few fruitless attempts to find what I figured had to be present, I finally ran across this pretty good list here: http://android-tips.com/use-keyboard-shortcuts-to-switch-between-applications.
Open applications:
Browser SEARCH + b
Contacts SEARCH + c
E-Mail SEARCH + e (not Gmail)
Google Mail SEARCH + g
Calendar SEARCH + l (this is an "L")
Maps SEARCH + m (now you can quickly access you location accurate to 2000 miles ;-)
Music SEARCH + p
Messaging SEARCH + s
YouTube SEARCH + y
You can add/change these here: Settings > Application settings > Quick launch (this isn't present on my Moment, but maybe there's another route?)
Just re-mount the sd card and copy the photos back to it from the PC.Hello,
Quick question. I just saved all of my photos from my memory card to my computer, I just unmounted my sd card to format it to erase the data. Is there anyway that I can resave the photos to my sd card?
so i've tried plugging my moment in to my laptop so i can get it to CL14. but its not detected...at all... i've tried removing the battery & reinserting it. that didn't work. i restored it to factory settings... i've also tried plugging it into another laptop... did the debugging thing in settings & none of it worked... is there any way you can help me?
How do i get my ringer (for a notification) to stop once i open up the message? I have a ringer and even after i am done reading the message i cant get the ringer to stop until it is completely over. Can someone help me with this?
follow the instructions here: Support - Article exactly do what it says and you should be fine...
Let us know if you need anymore help
All of my music is on my mac. Is there anyway to get files from my mac to my phone? I have tried using blue tooth and my phone says that it can't recognize any of the files.
I have also tried downloading a ring tone in MP3 format and my phone told me is doesn't support MP3.
Really?
My phone doesn't seem to support anything.
and yes I am a noob, and not a techie AT ALL, so I appreciate any help I can get.
Then it'll be "ho-ho" "icing" and "jelly""cupcake" is the name that google gave to android 1.5. 1.6 is called "donut"; 2.0/2.1 is called "eclair"; and the next release will be called "FroYo" (frozen yogurt); and the release after that will be called "gingerbread". notice that each release is named in alphabetical order.
Then it'll be "ho-ho" "icing" and "jelly"![]()
