Moon Reader + help
JohnB47
Edit: never mind. I found it in the FAQ section of the developers website:
"How to adjust reader options in Nexus 7, Galaxy Nexus or other android devices which haven't a menu key?
After you open a book, you can tap middle of the screen to invoke the reader bar for all customizable options."
Ta.
Simple question - how do I access the detailed settings, e.g. to set page turning mode, background etc. I've tried 'Options' but that's very general stuff. I'll kick myself when you tell me, I'm sure.
Thanks
Ta.
Thanks
When I click on options it shows me Visual Options, Control Options, Misc, More Operations.
These have always been enough to do what you are talking about
Yes but my point is that you can't see those options unless you know to tap on the screen to make the toolbar appear so that you can choose the options/settings icon. My problem with all this android stuff is that I often can't get started, cos I don't know the magic trick. Each app developer does things their own way and guidance is rare.
Cheers.
