More battery drain issues:(
johnbhoyc
Member
After fixing my problem with googlemaps draining my battery thanks to you guys on here. I still don't seem to be getting the best from my battery. Seems to me to be a problem with dolphin hd browser in particular mobi.mgeek.tunnybrowser. Is my only option to get rid of dolphin? I've tried reinstaling it but no joy. I really like dolphin too.
It will take up a lot of battery if you are actually browsing.
Strange that its above the screen in the list tho.
How long has both dolphin and screen taken up? (tap on each in turn to see)
Facebook seems to be a big culprit tho. I dont use it at all so can't say for sure, but you may need to uninstall it, or at least alter the frequency at which it polls.
Yeah I've been browsing quite a bit this morning so should expect quite a bit battery usage. Thing is tho it's quite excessive compared to the performance I got when I first got the phone. Brightness is set at 27%
It maybe worth noting that I have 3 batterys that I use in rotation. 2 x anker 1900mah and the origional sgs2 battery. I notice the same drain on them all evem tho they were once great performance wise.
In my second battery for the day and still the same drain issues. Been browsing just moderately but using the music player.
What does the (210s) mean?
