Help more noob questions
albertxvx
Just a couple quick questions since I'm a recent convert from my iPhone. I'm ob a g2x running 2.3.3
1: when I lock my screen and then unlock, I see whatever screen I was on before locking. It's annoying. Can I make it stop that and just go straight to the lock screen?
2: is there any way to make the long-press action shorter? It seems kind of slow for copy/pasting stuff
Thanks!
So you want it to lock the screen every single time you turn your screen off? Thats in the uh, security settings. Somewhere. Menu>Settings>Security/Password.
And uh, I am not aware of adjusting the time required for a long press. I too, would like to shorten it.
1. Unfortunately it is not possible. It's a big with the G2x that gives you a small glimpse of the screen you were last one before going into to the Unlock screen.
It's annoying. I agree.
The only workaround I know is shutting off the screen, turning it on and shutting it off. Next time you turn it on, it will not show the last app/screen you were on for a split second.
2. I'm not so sure about that one. I would say either root or a alternative launcher, but I've been using stock non rooted since the G2x, so I'm not really sure what they have now.
