Root MORE SPACE
Need to get rooted in case it not and a custom recovery then u can use some APS that will allow u to move thing to intern SD or ext sd
I like this phone but the 1gb is sooo painful anyway to increase the size?
You should have about 4-5GB of internal storage (when you first buy it), do you mean the 1GB of RAM?
It's not possible to increase the RAM size on any phone, it's a fixed amount.
The space where you're download your apps there is one that is 1gb and another that's 4gb
See you can see there its two different ones
