more system memory
  • Start date Start date
A
Android Question
Guest
How do I get more system memory on an LG Optimus Dynamic. It is a straight talk phone and I just bought it and it keeps updating apps that are already on it and I have only put three on there. I put those in internal memory. Problem is I don't have enough system memory to be able to update anymore stuff that was already on the phone when I bought it. Just tell me how to get more system memory and keep it so I can get updates for apps on my phone. Thankyou.
Hello and welcome to http://androidforums.com/,I would recommend buying a bigger external sd card,then theres plenty of apps in the playstore.or in the settings of your phone under applications,some can be moved to the external sd card,and that should allow more space for you.Plus if there is some apps on your phone that you do not use,you can go into the settings of your phone under applications ,you can manage them apps and uninstall update,that might help too.only do that to the apps you do not use,and make sure they are not system apps! If you need further information,please feel free to join http://androidforums.com/ ,by the way its free and there is forums that can help you out further with your phone!! Hope it helps!!
