Fabolous
Superuser
These metamorph theme files will install the stock Android lockscreen/dialer sliders onto a rooted, busybox'd, deodexed, 2.2 Droid X. It will work on any ROM or theme so long as the previous requirements are met
The lockscreen looks like this (just the sliders, other parts may differ depending on theme):
And the dialer answer/ignore sliders look like this:
Installation Instructions
As always, make a backup first so you can restore if you don't like this mod, or trouble strikes
-Download Metamorph from the market (it's free)
-Run MM once and make sure all checks pass
-If you run into issues (i.e. system not enough memory), download 'Busybox Installer' from market and use it to install busybox.
-Place theme file on /sdcard/AndroidThemes
-Open MM again and choose new theme
-Let it extract the theme
-Apply Theme
*Most likely your phone will reboot on its own. Don't be worried
Lockscreen Link
Fabolous-Stock-LockScreen.zip
Dialer Link (non-Apex users)
Fabolous-Stock-DialerSliders.zip
Dialer Link (Apex users)
Please update to the latest ApeX if this isn't included in your version!
-Apply Theme
Lockscreen Link
