Help Mosaic VII swype help...
randy_c
I am using Mosaic VII and swype was pre-installl as system file. I used root explorer to remove swype.apk and register with swype.beta.com and download swype but it would not install.
Can you guy help?
Thanks in advance
I think you need to reboot once you delete the swype.apk. You can read about it on the XDA forum of M7, I read about it a couple days ago.
