I often have the identical results with Chevy1's LV kernels, but the medV kernels work great for me. If you can download that you will probably be better off, or try to run the LV kernel at a lower rate. If you can't boot, that might not be easy.
Hopefully you did a nandroid backup before downloading the kernel? If so, flash that back, lower the speed and try to reload the LV kernel. If you didn't backup, reload CM with the stock kernel, then load an alternate kernel.
I like the Chevy1 kernel, but I never seem able to connect my droid to my PC with usb. I don't do that very often, so it isn't a major consideration. There are other kernels that work as well and might still enable usb connection.
