I'm having the following problem: I try to make a call and select the call to go through gv. I get the pop up showing it's connecting, but it doesn't connect and in about 20-30 seconds comes back with 'failed to connect' and gives me the option to retry using gv or call w/out gv. It does not happen on every call but often enough to be annoying, and these are numbers which have connected before.
Any one else experiencing this? is there some settng somewhere that i'm missing? or could this be some network glitch?
Also, is there a place to report problems such as this?
Any suggestion will be appreciated.
