moto droid question
emirsosa
im looking in ebay for a moto droid(nexus is expensive) so my question is that if i buy a moto droid that says bad esn(what this means?) can i use it here in belize(outside USA)? also can i unlock the moto droid myself like how i did it with iphone. i know to activate it i have to go to the phone comapny.
If the esn is bad it means your going to have problems connecting to a network. An esn is a unique number assigned to a phone to connect to CDMA networks, and if its marked as bad it could mean its stolen, or reported for some reason. I don't know if Belize uses CDMA networks or what carriers do, but you might want to google it. The droid won't work on GSM networks.
yea i know that droid wont work on gsm. here in belize we have cdma and gsm networks. but will the esn be an issue here in belize?
it'll be an issue anywhere. When i reported my voyager stolen last year, verizon locked the esn. Even after I recovered the phone it was unusable, completely bricked.
You also mentioned you had an iPhone. If you're going to try and use the same network, it won't work. iPhone uses GSM(sim cards) and Droid uses CDMA
Actually you should be able to activate as long as the network isn't associated. With VZW on any way.
Sent from my Droid using Tapatalk
yes i had a iphone and i understand that if i want a moto droid i would need to switch to cdma.
hey how about if i buy the moto droid do i need to unlock it or something like that?
yea man stay away from the bad esn phones. i just got one off ebay for about $350 i believe the seller was "doodadz" or something like that. great experience all together with the seller.nice refurbished phone, screen had no scratches but my earpiece speaker seems to be a little messed up, could be blown im not sure but it wasn't that big of deal for me and well worth the the price to get away from my old bb storm.
if you buy one with a clear esn such as a refurbished one you can just activate it online at verizon.com or take it into the store and they will do it, but probably for a fee.
i dont mean using it at USA. im from belize so if i bring the phone to belize does it need to be unlocked or can i unlock it
