Moto G Reboot Loop
I rooted my Moto G and I tried to change the screen DPI. I tried to reboot my phone, and then it went into a reboot loop. It comes up with the white root screen and then goes into a blank grey screen and stays like that for a few seconds before going back to the white root screen. I tried doing stuff with the recovery options etc but nothing helped. Any help would help :)
Welcome to the forums, Banana4Life!
Which version of the Moto G do you have so we can get this moved to the proper forum? Also, do you have a backup, nandroid you can restore?
I have fixed the problem using by following this tutorial https://www.youtube.com/watch?v=laU6NQ0LxR0 I used the restore no data wipe bat file. Worked fine, only problem is, is that I think I now have the US version but I live in the UK. I cant update to a new version. Will just doing a reset work?
