Root Motofail doesn't work on .906 for me!
It says I have a read only file system. I have no idea how to fix that please help
Try downloading it again. Try restarting your computer and your phone before you run it. Make sure that USB debugging is enabled (settings->applications->development).
I thought it had something to do with Android SDK and I don't know how to work that.
No, it's not necessary to install or know anything about the Android SDK. All of the pieces that Motofail needs from the Android SDK are included in the zip file that you download. You do, though, need to enable USB debugging using the steps I gave in my post above in order for Motofail to root the phone. (It was the same with Pete Souza's one-click method that worked before the 906 update.)
