Help Motonav, Orientation/Accelerometer problems
seanos
When using the Milestone in the car mount, and start Motonav, find when turning (generally going at a reasonable pace), that it switches briefly to portrait mode.
Fairly distracting.
Only fix I assume is disabling the auto-orientation before starting motonav.
Hopefully fixed in a later update...
OK, thanks for letting me know.
Maybe was once-off, random problem, will give it a proper test during the weekend.
Se
In case anyone else experiences similar, found handiest fix is to open open the slider when using carmount, forcing it to stay in landscape.
