Root Motorola Atrix 2 on t-mobile prepaid plan
From my understanding it will function on a slower network like 2G, EDGE. The radio in the Atrix is designed for AT&T networks that use a different band. Maybe somebody can explain it in more technical terms. That's my limited understanding. Hope that helps.
Also...you will need an unlock code from AT&T or a retailer that sells the code. I think they sell for about 15 US dollars. I'm just going from memory on all this.
I have my atrix2 on strait talk. I just bought the sim and added money . Works great fast data. Allways in blue color 4g
i have tried that and found Atrix2 will not work on Tmobile for 4G data, But i can use the data using 2G speed.
I also tried to use AT&T's 3G data (prepaid) for this phone and found that also will not work.. with tmobile data was atleast working with 2G speed, but with AT&T prepaid the data is not at all working.
