My battery is also very BAD !!!
I have to charge it 2-3 times a day ! I am really confused !![]()
Do a factory reset. Mine was the same way draining about 20% an hour. After factory reset I went 30 hours and was still at 50%.
).Do a factory reset. Mine was the same way draining about 20% an hour. After factory reset I went 30 hours and was still at 50%.
Your strategy seems sound, it's something I'd do to test out the battery life. So I guess you're rooted if you're using Titanium backup.My battery life since launch day has been quite mediocre..
I'm quite tired of it, but I have faith in both moto and the atrix, so I'm going to give the factory reset option a try, since it appears to have worked for many people here.
I've really customized my atrix in these past few days though, so I'm assuming running the "Backup all user apps + system data" batch in Titanium Backup and copying the entire phone's storage to my computer should back up the phone completely?
I'm looking to factory reset my device, and then go a day or two without installing ANYTHING, and testing the battery.
Then, I'll restore everything and compare my battery results.
So, is my plan ok for backing everything up?
Can someone tell me if this is about right. I have been off charger for just over four hours today. I have received 4 texts, 7 emails and placed one phone call. No internet or any other activity and wi-fi is turned off. I am now at 80% battery. Seems like it should be better than this. Just to let everyone know. I have run the battery down and turned the phone off and charged it all night long.
Wait, so for those who drained their battery to 0% and had the atrix turn off automatically, and then charged it until the little battery icon showed 100%, how long did you leave it at 100% connected to the AC Adapter?
Mine's now at 100% and has been there for probably about 30 minutes or so. Should I take it out now and begin testing? Or should I give it the night to rest?
