for caller ringtones, go to contacts, select the contact, click menu button (bottom left), click edit, go to additional info, and change the ringtone
EDIT***
there is an app called Ringo Pro that will allow you to assign different ringtones for contacts when they text message you, but for caller ringtones, you can already set that up, you just need an app for the text msg ringtones
