skunk
does not upgrading to ics have an effect on the phones performance? or is there something else goin on?
ever since I started getting the notice that the OTA ics upgrade was downloaded I keep hitting 'install later' kinda annoying, but I noticed that the phones performance has gone to sh*t, wifi wont work half the time, the phone is REALLY slow, lags like crazy (ie: I tap on an app, it glows, then like 5-10 sec. later the app opens), weatherbug wont update anymore (the weather info not the app itself), and I constantly have to restart the phone for anything to work... so, is it because I wont upgrade, or is it another issue? anyone else have this issue?
Thanks in advance.
running GB 2.3.4 currently unrooted.
EDIT: also batt running out faster (I have the OEM extended batt)
Thanks in advance.
