Motorola Droid HD Mirror Screen Protector
vb4life
Has anyone used the Motorola Droid HD Mirror Screen Protector for their droid? It looks pretty cool, but I was wondering if anyone has real world review of the mirror screen.
Never heard of it but I'm bumpin this...id love a good screen protector cuz every one I've used has actually attracted more smudges and lint..
hmm looks interesting. i'm thinking of modifying that so it can fit on the back of the slider instead.
I have used it. I love it on my LG Dare, 50/50 on the droid. The screen is bright enough for outside use on the droid, not so much for the dare. I just dont think it looks as nice on the droid.
Neat looking but the big question is regarding thickness....too thick will reduce the touchscreen sensitivity....
the "privacy" screens that VZW offered early on reduced touch sensitivity, so they pulled them....
anybody who has purchased please give us some feedback....would love to give one a try....
It wasnt horrible on the touch degradation but i did notice a slight lag.
TB, does the product have that much reflection in real life? Like it actually turns into a handheld mirror when the screen is off? Also, I know you may of hinted at it in your previous posts, but would you recommend the mirror screen?
yeah it pretty much turns into a mirror when the screen is off. I like the screen because it is cut right and i dont get as many bubbles when putting it on as others. I just put on another one and it isnt really that laggy as the first one was. (could have been the phone at that time) yeah id recommend if you like the mirror look.
Thanks for the heads-up! I will be looking into one of these. I'll search, but are there other brands and if so which one is better(will last longer)?
I've used a lot of mirror screen protectors and they all have some bad effects with sunlight. You usually have trouble seeing anything in direct sunlight.
This would look awsome on the back of the screen (when u slide the keyboard out)..so u can see when ur taking yourself a pic !!!!
