Once you root the device, you can overclock it to up to 1.2 GhZ, supposedly stable. Mine runs at 900 MhZ stable, so..it's possible. Battery life is pretty shit though.
but pretty shit how bad do you mean? and will it ran fast properly on a 1 ghz?
At 1 ghz it is basically on par with a snapdragon. At 1.2 it is faster
im planning on buying a used motorola milestone and the guy says its already rooted is there a way to check if the phones working properly? and if i buy it and its not working properly is there a way to set it back to origional factory settings?
