edlex
Android Expert
Just got one. I also used coupon code THANKYOU for 10% off.
Battery HF5X (1700mAh) for MOTOROLA PHOTON 4G : Batteries
3 batteries, wall charger for 12 bucks on ebay. They are from Hong Kong, take a couple weeks in shipping and last a bit more then half as long as stock but well worth it for backup batts.
Meh. I'd rather buy one of those external batteries with a USB charger than put one of those Chinese pieces of crap in my MoPho. ...haven't had the best of luck with Fleabay Li-ion batteries.
It would be nice, however, if the OEM's wouldn't bend us over to get a good battery.
You can get the OEM HF5X off Ebay for $16. I got one and it's just like my OG Battery.
Factory New Battery For Motorola Photon 4G MB855 HF5X | eBay![]()
