theprorules
So I plan to root my motorola triumph soon and flash miui on. I'm really scared of bricking my phone. I know about recovery image and cmw but will recovery image always work? If not is there anything else that always works.
trust me i would know! lol so your safe to root and flash roms as you'd like. just remember to keep a nandroid backupYes there are fixes. I wouldn't say impossible to brick, but darn near. We can help you out if you run into issues. Don't be afraid!![]()
this phone is impossible to brick...trust me i would know! lol so your safe to root and flash roms as you'd like. just remember to keep a nandroid backup
also the most harm you can do to this phone is boot loop. which is easily fixable by reflashing a rom or restoring that nandroid backup that you should make as soon as you get clockwork mod recovery on your device
Kewl kewl also what are adb commands
The only way I could think of bricking it by using QPST and flashing a .nb0 file from a totally different phone... But I'm not going to test that lol.
So long as you use CWM and follow the steps that the creator leaves for installing the rom you should be safe.![]()
Yeah that would probably do it like!! Never thought of that but yeah I'd say flashing a .nb0 from another phone would toast it. Still maybe able to recover in Linux if you could get in download mode though. Idk its hard to say and I'm not trying like!!
How exactly can you brick? I just want to know what dumb experiment to avoid.
Correction re wiped and installed works fine.
Hello, first time poster here. seems i have bricked mine? stuck on original non animated motorola logo. i did a wipe data/factory reset and also a format system thinking i had the rom on there ready to go. somehow it was misplaced. so i tried rebooting the phone, also boot into recovery, and boot into bootloader mode. any help would be greatly appreciated...
Did you use the correct CWM recovery.img on the phone, cause when i personally flashed mine at first i accidentally downloaded the newest CWM which i believe is for tablets and it would only show the stock moto image and then a battery image, i fixed it by finding the correct CWM recovery img 5.0.2.6 i believe, easy to find on here and replacing my non working one with the correct one
wipe data/factory reset is fine, but if you had the zip file for your rom on the SD card and u Reformatted you may have wiped the sd card, deleteing the zip files, in which case your problem is fixable as long as your still able to access download mode and CWM recovery mode
if the phone doesnt boot into android, but still can go into CWM then you can place the files on the sd using an sd reader and ur pc, then reinsert the sd in the phone and boot into CWM and rewipe/reflash
Possibly, as long as u never installed the new rom, but clearing you sd if that what happened would have deleted some data, but i was simply trying to clearify what's actually working, and figure out if u made it any further then formatting so I can try to further assist you, so booting while holding power,volume up,volume down doesn't goto cwm recovery?first of all, thanks for the hasty reply, second, i did use the CWM recovery img 5.0.2.6 wipe data/factory reset and format so im unable to get into CWM recovery mode just stuck on motorola logo no matter which way i turn it on. so you're saying if i put my recovery img backup onto the sd it is possible to boot into android?
Ok so I took my sd card put into a sd card reader, transferred over the original recovery img and so I am now able to boot to CWM recovery as well as download mode but not the android system. So im thinking i'll be able to load a new rom and flash it and hopefully get this going again, thank you so much for your help!
alright! so, i redownloaded the recovery and rom and was able to boot up into miui rom but now the problem lies in this pesky little message that keeps popping up, "The process android.process.acore has stopped unexpectedly. Please try again." This seems to be the only problem with this beautiful rom...
[FIXED] Cleared data in contacts under manage applications
Thank you guys so much for all your help, I really appreciate it!!
Good news!! We are allllll good on my end, rewiped, reflashed the rom and things are working perfectly. Quadrant standards benchmark is giving me 2000-2300, so oo close to nexus tablet!! Thanks again, everyone's been a real help!
