Root Motorola Triumph CM7 Issue with screen orientation
protobyss
Not sure if this is where to post this but an issue recently came up that is irritating me a bit.
Not sure exactly when it happened but it happened sometime after installing TheOC Kernel (latest available version) and 108 Tweaks scripting that my screen stopped changing orientation in all of my apps when I turn the phone.
I would give you the exact version of all my software but I am calibrating the battery at the moment and it is still currently charging.
Any help would be greatly appreciated.
have you checked if auto rotate was on? lol :D
Is this setting under the CM7 Performance setting? I've been durdling around in the settings on the phone and I can't find anything other than the Rotate Acceleration options for 90, 180, and 270. :eek:
Try rebooting after charge
I just did a calibration and dead'd the phone and full charged without turning on and I still have the issue. I just realized I am using a version that was discontinued last year. I will try flashing a more recent CM7 ROM and see if I am still having the problem.
Also loading up ICS Codename Android for funsies.
if you have certain launchers downloaded amd intalled theres options there as well to turn auto orientation off n on..i was messing with it yesterday with launch pro and it overides the cm7 settings depending which one u used last will over ride the other,,,if u did download a launcher with those features you can find it in preferences,,when you hit the menu you at home screen
