Motorola Triumph Optimization
Virginmobileguy
Hello,
Well first of all you have to have a Virgin Mobile Motorola Triumph of course:) in order to do this process that ama start showing you guys in a bit.
Step1. Download Gingerbrake from GOOGLE simply type in "GINGERBRAKE.APK" and download any of the files you see that are able to download this app.(THIS WILL NOT HARM YOUR PHONE)!!
STEP2. Now that you have "GINGERBRAKE" root your phone (IT WILL REBOOT ON SUCCESSION)
STEP3. Download "4SHARED" from the ANDRIOD MARKET
STEP4. Now that you have installed 4SHARED and created your account type in on the search box "SETCPU.APK"a list will show up get any of them they all work now press and hold to add to your account now simply press it and downloaded instal.
STEP5. Will need to instal CWR ClockWorksRecovery go to this link:
forums.androidcentral.com/motorola-triumph-virgin-mobile/107848-how-flash-clockwork-recovery-motorola-triumph.html
-Note- You'll need to Sign Up for this Forum just a few clicks away no biggie right?By Signing Up you'll be allowed to Download the file need to begin the CWR and FUTURE DOWNLOADS WHO WILL BE NEEDED!.
STEP6. NOW that you have done what the link specificly told you what to do you should have gotten your CWR installed on your phone by simply pressing "VOLUME UP DOWN WITH THE POWER BUTTON ALL TOGETHER"
-NOTE- Now we will need to instal "UMPH KERNAL" on to your phone using Clock works Recovery (CWR) which is by far better than that of the Stock Motorola Kernal!
-2ND NOTE- You guys Know the Motorola Triumph runs on a 1ghz snapdragon processor by instaling the UMPH KERNAL your phone will be at 1.9 ghz HERES HOW: Download Umph kernal here's a link to it: Umph-Kernelv1.zip
STEP7. After downloading the Umph Kernal download "ANDRO ZIP"from the ANDRIOD MARKET now simply make a new folder name it "UMPH KERNAL" go to your Download folder look for the Umph kernal Zip. Grab and move to the folder who was just created "UMPH KERNAL" Now tap on the the Umph zip kernal and it extract the files to that specific folder it should say "EXTRACT FILE HERE"
Once done, LEAVE THE SD
CARD IN!
After this reboot your phone in ClockworkMod
Recovery.(VOLUME UP DOWN HOLD POWER-BUTTON ALL TOGETHER)
Once you are in the recovery, go to install Zip from SD
Card option.
LOOK for the FOLDER YOU PLACED IT IN "UMPH KERNAL" select the kernel zip file and flash / install.
After the installation is complete, reboot your device.
Apparently it
