motorola uno connection problems
Hi, my xoom for some reason over the last week has come up with the problem cannot connect to server when playing Uno. The signal strength is excellent and internet sites work fine,it is just Uno (gameloft) which has started this annoying trait.
Any ideas what I should do to get things back to normal. I have reinstalled the network and Uno but it is no better. My wifi router is netgear vmdg 280
:mad:
Hi there timetrialist and welcome aboard! Never played that game really, but have you tried clearing the data? Have you reported this issue to the developers? You can also try asking here and see if others are experiencing this and can offer a solution. :) Have you tried using data BTW?
Android Games
Keep us posted and enjoy the forums. :D
Welcome to the forums :)
Hopefully we can help you with any issues you might be having with your device.
Thanks for joining and enjoy the site :D
Android Games
Hi, not too keen on erasing data as have hundreds of thousands of points and this problem has only occured after more than a year of trouble free playing. I have just reported the problem to the "Uno team" as you suggested and will see what they can come up with.
Many Thanks
