Help Mount as Disk Drive Frustrations...
turbomentor
Unable to connect my DINC to my PC to look around, move some files etc.
Yes, I have USB Debugging checked. Yes, I select "mount as disk drive" when prompted.
Appears to be charging just fine after I attach it to my PC, then I go to open Windows Explorer and Explorer sits and spins then crashes. In fact, when I close Explorer and go to my desktop, all I get is the wallpaper (no desktop icons etc). Then, when I unplug my phone, computer acts normally. Same PC that I used to root my phone mind you, so somehow it was able to connect to my phone for that process.
Have rebooted the phone as well, all to no avail. One of the advantages of Android and the DINC is the ability to hook up to a PC and move files around...not being able to do this is becoming a bit of a PITA...hope someone can help out.
